Discussion topic: Stuck on update
This message was authored by: Jessica56
Stuck on update
My sky box started to update itself mid programme at 20.15 and its been stuck on a constant loop of showing me the 'you will be ready shortly...' and then the 'when the screen goes blank...' messages over and over ever since. I phone sky the bloke told me what to do but as took so long he gave me instructions and I followed them with call ended but again hasn't worked 🙄 ive hard reset it, unplugged it, followed all instructions from sky etc any advice?
Re: Stuck on update
You could factory reset by holding down the left and right arrow vuttons on the top of the box (not on the remote) whilst powering the box on, this will wipe out all recordings and planner entries
Or force a software udate (see my FAQ) but I'm guessing that is the one Sky gave you instructions for
Please note: Free (advert supported) Hayu content is available via the On Demand section of your Sky planner, you DO NOT access the free content via the Hayu app!
Avatar for Jessica56
Re: Stuck on update
I have a sky q box it doesn't have arrows can I still do this on a sky q box?
Re: Stuck on update
The reason @Annie+UK posted what she did was because you had posted this in the Sky+ box forum so I have moved this to the Sky Q one for you.
Re: Stuck on update
Hi @Jessica56
https://www.sky.com/help/articles/sky-q-box-wont-turn-on-v2#:~:text=Restart%20your%20Sky%20Q%20box,b...
Re: Stuck on update
Thank you didn't realise I had done that
Re: Stuck on update
Already tried these steps
