Discussion topic: Stuck on error mr108
Message posted on 18 Apr 2024 10:28 PM
Followed all the steps in previous posts nothing works! Got to this stage as Netflix wasn't loading so followed the shows and now stick on the for 2 days
Message posted on 18 Apr 2024 10:40 PM
Re: Stuck on error mr108
Hi @griffter1
Try and reset the connection on the mini box, Settings > Status > Connection to Sky Q box and click reactivate, it will ask you to press the WPS button on the front of the main q box or the sky router (if you have sky broadband) assuming your on WiFi and not hardwired with Ethernet.
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 18 Apr 2024 10:42 PM
Hi thanks for the reply but it won't let me do anything just stuck on that page
Message posted on 18 Apr 2024 10:43 PM
Could you share a photo of the screen you are seeing please ?
Message posted on 18 Apr 2024 10:46 PM
Message posted on 18 Apr 2024 10:51 PM
I can't see that, do you want to PM it to me ?
Message posted on 18 Apr 2024 10:54 PM
Or just try this on the main Sky Q box
Home menu - Settings - Status. Does Watch on Sky Q Mini Box have a tick? Even if it does Select it and then Select Reactivate on the right hand side.
Message posted on 19 Apr 2024 08:05 AM
Hi @griffter1 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
Message posted on 14 Jun 2024 09:09 PM
Did you manage to solve this (and if so how please?) I've got the same now and started the same with Netflix not loading. Stuck in this even after I reboot
