Discussion topic: Can’t connect to broadband router - remote select confirm
This message was authored by: Lianda16
I have a connectivity problem and am unable to watch tv on my sky mini box.
it is not connected to broadband and when I try to reset it I am unable to select confirm - nothing happens when I select it. I can only select cancel. My broadband is not with Sky.
Help please!
Re: Can’t connect to broadband router - remote select confirm
Help please!
Hi @Lianda16
Reboot the mini as above.
