Discussion topic: Static caravan sky
Message posted on 21 Mar 2025 04:17 PM
Static caravan sky
I have Sky q in my main home and I would like Sky in my Static caravan holiday home. I don't have apple TV/PlayStation. I do have good WiFi in the caravan. Can I use multi room box?
Message posted on 21 Mar 2025 04:20 PM
Re: Static caravan sky
Your current Sky Q equipment can only be used at your main address.
Message posted on 21 Mar 2025 04:21 PM
@Ade74 wrote:Can I use multi room box?
Yes if your caravan is sitting outside your house (as the boxes connect to each other).
Alternatively, look at Sky Go. (You'll need a device to host it, such as an iPad etc.)
Message posted on 21 Mar 2025 05:51 PM - last edited: 21 Mar 2025 05:52 PM
@Ade74 in that case you would need to take out another full subscription for your static caravan if you want the full Sky service
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 Mar 2025 06:45 PM
@Laing1 is that the case even if the static caravan is on their property? I read the original post that it's on the property and has wifi to the main house but I could read it either way.
Message posted on 21 Mar 2025 06:49 PM - last edited: 21 Mar 2025 06:50 PM
@Anonymous
The OP described it as a static caravan holiday home which suggested to me it's away from their main residence.
Perhaps you could clarify.
Message posted on 21 Mar 2025 07:03 PM
@Daniel0210 wrote:
@Anonymous
@Daniel0210 thats how i read it and knowing Caravans and Statics its very unusual to have a static caravan at your home address unless you have a lot of ground space to site one
Message posted on 21 Mar 2025 08:14 PM
@Laing1 wrote:
@Daniel0210 wrote:
@Anonymous
Or having some kind of extensive house rebuild 🙂
Message posted on 21 Mar 2025 10:43 PM
It's not on my land it's on a holiday park. Thanks for all your advice. Seems I need a subscription separate to my home
Message posted on 21 Mar 2025 10:47 PM
@Ade74 wrote:It's not on my land it's on a holiday park. Thanks for all your advice. Seems I need a subscription separate to my home
Yeah. And you need Stream there. Q requires a dish and the mini can't operate on its own.
