Discussion topic: Static caravan sky
This message was authored by: Ade74
Static caravan sky
I have Sky q in my main home and I would like Sky in my Static caravan holiday home. I don't have apple TV/PlayStation. I do have good WiFi in the caravan. Can I use multi room box?
Re: Static caravan sky
@Ade74
Your current Sky Q equipment can only be used at your main address.
Yes if your caravan is sitting outside your house (as the boxes connect to each other).
Alternatively, look at Sky Go.  (You'll need a device to host it, such as an iPad etc.)
@Ade74 in that case you would need to take out another full subscription for your static caravan if you want the full  Sky service
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Laing1 is that the case even if the static caravan is on their property? I read the original post that it's on the property and has wifi to the main house but I could read it either way.
@Anonymous
The OP described it as a static caravan holiday home which suggested to me it's away from their main residence.
@Ade74
Perhaps you could clarify.
@Daniel0210 wrote:
@Anonymous
@Ade74
@Daniel0210 thats how i read it and knowing Caravans and Statics its very unusual to have a static caravan at your home address unless you have a lot of ground space to site one
@Laing1 wrote:
@Daniel0210 wrote:
@Anonymous
@Ade74
Or having some kind of extensive house rebuild 🙂
Avatar for Ade74
It's not on my land it's on a holiday park. Thanks for all your advice. Seems I need a subscription separate to my home
Yeah. And you need Stream there. Q requires a dish and the mini can't operate on its own.
