4
This discussion topic has been answered Discussion topic: Sports
This message was authored by: Smithypa
Sports
Tnt hd not working says i have too upgrade but I'm subscribed too them
This message was authored by: SKY1992bf Answer
Re: Sports
@Smithypa  Are you paying sky or bt/tnt directly
if the latter you need a separate hd add on subscription added to your bt/TNT subscription
if the former is tnt sports listed separately on your sky bill
Re: Sports
Avatar for Smithypa
Re: Sports
Paying sky it's on my bill
Re: Sports
@Smithypa  Are you able to view the sd versions if you are the only thing I can suggest is you call sky and get them to check your account and if needs be they can re issue the signals to your box
Avatar for Smithypa
Re: Sports
Sd channels yes been on too sky they are saying alot of people having issues which I don't believe just been fogged off
