Discussion topic: Sound lag
Message posted on 28 Jan 2025 09:51 PM
Sound lag
Sound is badly out of sync on programmes like Star Trek, Farscape & Andromeda... (lips move but no sound, or sound but no lip movement) but also on SkySports (NfL).
What's the fix please?
Message posted on 28 Jan 2025 09:59 PM
Re: Sound lag
Hi @Rabbitoh
Message posted on 29 Jan 2025 09:45 PM
Re: Sound lag
Thank you very much for that.
Is there anyone here from Sky who can confirm? Sounds like this could be quite tricky with major opportunities for getting it badly wrong......
Message posted on 29 Jan 2025 10:28 PM - last edited: 29 Jan 2025 10:29 PM
Re: Sound lag
No: that's not how the forums work.
Not really: there's the outside possiblity that a reset can go wrong (just like a box can fail in service at any other time) but in such an event Sky replaces the hardware for free.
Message posted on 29 Jan 2025 11:23 PM
Re: Sound lag
Ok thanks. Find this quite confusing, some things Sky pick up here...
