3
This discussion topic has been answered Discussion topic: Sound issue
This message was authored by: DKN1
Sound issue
My sound keeps pausing for a second then normal. Getting annoying when watching a movie.  Can't get sky number. Can anyone help so can speak to tech services
Re: Sound issue
@DKN1
Have you tried a reboot of your main box?
~ press the 🏠 button
If you definitely need to contact Sky, then if you already have a Sky Mobile or a Sky Talk landline call free by dialling 150, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum.
Note: We’ve been informed the lines are busier than usual at the moment and that’s likely to be worse over the Christmas and New Year period.
Re: Sound issue
@DKN1
Avatar for DKN1
Re: Sound issue
Thank you.  Yes have tried the reboot switching on and off. Even tried the number to call.  Keeps referring back here. Didn't have the landline one tho so that's a massive help thank you
This message was authored by: Mark182004
Re: Sound issue
Several posts on here regarding sound drops I think the new software update may have caused this.
software version Q230.000.14.00L (5nf3ptk)
hardware version 32B12D
