Discussion topic: Sound but not Tv from sky Q
Message posted on 04 Jun 2025 10:22 AM
I have no picture. There is no blue screen just black.
I have sound from going through the TV.
have no idea what has happened. I sorted out my Broadband from this community but now have a problem as can't watch an TV.
It's been a nightmare since the fault with Sky a couple of weeks ago
Message posted on 04 Jun 2025 10:38 AM
Re: Sound but not Tv from sky Q
Hi @Feliciy
Have you tried rebooting your Q box?
If you still have a black screen , make sure that the Television is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Message posted on 04 Jun 2025 10:58 AM
I have done all of those things.
my tv just has the sound come through. There is no picture. I cannot see anything on the screen. It is completely black.
has my TV Broken... maybe. But why has it still got sound!
Message posted on 04 Jun 2025 01:16 PM
A few things to try here.
When you turn your Sky Q box on, do you see the normal Sky logo as it's booting up, or do you see nothing at all?
Is there a "no signal" message (or something similar on your TV)?
Have you tried a different HDMI port on the TV?
Is there a chance that anyone has fiddled with the settings on the TV?
Have you ensured that the HDMI lead is firmly seated into the sockets (both TV and Sky box)?
Have you tried a different HDMI lead (sometimes leads break)?
Pete.
