Discussion topic: Sound breaking up on mini box
This message was authored by: Loopyluk
Noticed over the past few days the sound from my mini box is breaking up. Regardless of streaming, live TV or recordings. I've ruled out my sound bar and there are no issues with the sound when streaming from my TV. It's really annoying. Tried resetting everything but still no change.
Re: Sound breaking up on mini box
Hi @Loopyluk
Fid you try a Reset Settings in the Main Q box hidden menu.
Once the main Q box is back up and running reboot the
To reboot press Standby on your Sky mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini  box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Avatar for Loopyluk
Thanks so much for that instruction. I completed it but it didn't work. I then reset my broadband router on the mini box and guess what, it seems to have rectified the issue.
