Discussion topic: Sky Q mini suddenly connected to wrong network
Message posted on 15 Mar 2025 12:15 PM
One of my 2 sky mini boxes isn't working this morning - not connected (fine last night).
In network setup, its now showing some other random network not my BT one. Main box and other mini are fine. When I do 'reset' it just says it can't connect to my network - but I'm not surprised because it's the wrong network. How do I get it to sort itself out and get the right network? Tried rebooting but no change.
Message posted on 15 Mar 2025 02:54 PM
Re: Sky Q mini suddenly connected to wrong network
@SOOKIE+D as Sky is not your broadband provider mini boxes do not connect to your bt wifi the connect direct the the main box by way of a mesh signal from the main box. To reconnect your mini box try rebooting your main box then your mini box
If that doesnt work try a network reset on the mini box and it should ask you to press the wps button on the main Q box or nearest piece of Q equipment
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 15 Mar 2025 05:26 PM
Hi @SOOKIE+D
Carry out a Network Reset on the minis. Start with the one nearest to the main Q box
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
