Discussion topic: Sound Dropout on Sky Sports Main Event Channel
Message posted on 20 Oct 2024 03:00 PM
Re: Sound dropout on main event
401 dropping out every now and then for 30 secs - 1:30!!! Not good enough Sky! Never had this problem when I was with Virgin!
Message posted on 20 Oct 2024 03:35 PM
Have you actually contacted customer support to raise this problem?
Message posted on 20 Oct 2024 03:39 PM
Yes!
Message posted on 20 Oct 2024 03:45 PM
Mine was ok last night which surprised me... seems to work ok when you go from hd channel 402 then select ultra hd.. never had this problem until this year so seem strange
Message posted on 20 Oct 2024 03:53 PM
Seems only to be an issue on everything except Premier League
Message posted on 20 Oct 2024 03:54 PM
This is an issue again but you still have marked this as answered
Do the right thing and open it again and let us know of how and when you plan to fix this.
Message posted on 20 Oct 2024 05:17 PM
I was one of the viewers having the sound dropping out problem back during the summer. The problem went away after a Sky contributer to this discussion said they had fixed the problem. I am watching the Liverpool game on Sky ME UHD now, my Sony TV says that the sound is "Dolby Atmos -DD+" and the sound is perfect.
Message posted on 20 Oct 2024 05:25 PM
Yes, I am the same. I am watching the Liverpool v Chelsea Game on 401, i have a Sony Bravia and the sound is Dolby Atmos Plus. The sound issue does seem to be resolved or at least much improved.
Message posted on 20 Oct 2024 05:45 PM
UHD is unwatchable with the sound dropouts ....HD is fine
Message posted on 20 Oct 2024 05:50 PM
Use 402 hd then use the uhd prompt and it works fine.. no sound drop out...
Liverpool Chelsea was OK first half but second half so far there's been numerous audio dropouts on UHD.
Message posted on 20 Oct 2024 05:51 PM
Come on Sky sort this mess out, sound dropping out every few minutes on sky sports UHD and lip sync issues on the same channel, completely unwatchable and you are charging me £5 a month for this !!!
Message posted on 20 Oct 2024 05:52 PM
Oh and forgot to mention been like this for months
Noticed it drop maybe 4 or 5 times per game historically.
Just watching Liverpool vs Chelsea, it has cut out maybe 8 times between the 2nd and 3rd goals. The 3rd goal was scored in silence. The problen has gotten worse if anything.
Message posted on 20 Oct 2024 05:56 PM
Please delete this as an answer as the problem is back, so looks like it was never fixed by Sky.
