Discussion topic: Sooo confused
This message was authored by: Stressedskyuser
Sooo confused
I have sky Q hard wired into Sky hub.  I think have 4 mini boxes upstairs.  I want to make sure they are used as hotspots as the signal drops off at the back of the house and a sky booster just seeems to make it worse.  Should the 2.4 and 5g wireless on the sky a box be on or off ?   Thanks
Re: Sooo confused
Needs to on @Stressedskyuser assuming your minis are on WiFi
Avatar for Stressedskyuser
Re: Sooo confused
Yes minis are on WiFi except one which is hard wired to the router
Re: Sooo confused
Need both on afaik. Think they only do 2.4 for wifi hotspotting and they need 5 for the Q mesh.
of course, having both on then messes up your Q connection to the internet I expect.
Re: Sooo confused
@Stressedskyuser as has been said you need both 2.4 aned 5 Ghz on but as you have Sky as your broadband you will receive both 2.4 and 5Ghz  as hotspots
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Sooo confused
Aha thanks for the correction
Re: Sooo confused
@Chodley no worries just another oddity 😀
