Discussion topic: Some channels showing ‘technical fault’ message, recordings not working
Message posted on 03 Nov 2023 10:35 AM
Can't use pause, rewind or fast forward function
Message posted on 04 Nov 2023 10:04 AM
Re: Some channels showing ‘technical fault’ message, recordings not working
Message posted on 04 Nov 2023 10:06 AM
Hi @Seunson Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
Message posted on 06 Nov 2023 10:14 AM
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Message posted on 06 Nov 2023 10:17 AM
Thank you- switch off, unplug, switch back on worked! Ridiculous really!
