This discussion topic has been answered Discussion topic: So fed up with multi room
Message posted on 20 Sep 2025 06:39 PM
Multi room in kitchen is always going off, I've done everything I have been told to do and got nowhere this time! I think it's time to cancel it
Message posted on 21 Sep 2025 11:56 AM
If you do end up needing a new mini box it'll probably be via a 'doorstep box swap' whereby a courier company (usually DPD in the UK) deliver a new box and take your pre-disconnected faulty box away rather than dispatch an engineer.
Message posted on 20 Sep 2025 07:42 PM
Re: So fed up with multi room
Hi @kattim
Unless you can connect the mini by Ethernet the best procedure is as follows.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 21 Sep 2025 03:09 AM
You might have a faulty box, probably the kitchen mini? Do this:
call Sky tech support. Remain calm. Do what they ask. If no result, ask then to arrange an engineer visit.
when the engineer calls, he will more than likely replace a box/s. Sometimes the main box has to be replaced.
if the box is faulty you won't be charged.
i have several minis, no issues. I had an issue with a box once but got it replaced and all was well again, zero issues since.
Message posted on 21 Sep 2025 11:40 AM
Thank you for your reply I did all of what you suggested yesterday to no avail. The main box was no trouble so last evening I could watch that when I finally sat down to relax. To my surprise this morning in the kitchen, everything was working perfectly! Gremlins maybe🤔but very annoying and frustrating especially as it was bucketing down all day.
