Discussion topic: Sluggish minibox
Message posted on 31 Mar 2025 01:40 PM
Sluggish minibox
Changing channels via the mini box is not instant. On occasions the screen has gone blank, a message indicating a technical fault has appeared then disappeared as the selected channel appears. More usually there is a few second delay. I have had thi mini box for some time - could it need replacing?
Message posted on 31 Mar 2025 01:53 PM - last edited: 31 Mar 2025 01:53 PM
Re: Sluggish minibox
@Yelnats1 wrote:Changing channels via the mini box is not instant. On occasions the screen has gone blank, a message indicating a technical fault has appeared then disappeared as the selected channel appears. More usually there is a few second delay. I have had thi mini box for some time - could it need replacing?
Switching channels is never 'instant' but should take no more than a couple of seconds.
(The signal is cached on the main Q box first and then send wirelessly to the mini)
If there is a 'fault' it could even be with the main Q box - not unusual for hard drive issues to impact the mini. Or a weak internal network.
You'll need to call Sky to see what they advise though.
Message posted on 31 Mar 2025 02:08 PM
Thanks for that!
In relation to your last point I cannot find a number that connects me to an actual person with whom I can discuss this! Information I've been given takes me on a loop that doesn't help. Are you aware of a number I can ring? When installed a few years ago the put in a booster to the room in which the box lives. To date I've had absolutely no issues...
Message posted on 31 Mar 2025 02:20 PM
Call the number on the help page - it seems saying nothing is the best way to talk to someone...
Message posted on 31 Mar 2025 04:17 PM - last edited: 31 Mar 2025 04:19 PM
Hi @Yelnats1
On Sky Broadband you can use the WiFi booster to connect to your router or your main Q box. That's provided it is a Sky Q WiFi booster.
If you main Q box is successfully connected to your Sky router then you can use the Q booster located between your main Q box and the mini.
Assuming the main Q box is connected correctly you need to set up the Q booster as follows.
Position the booster approx midway between the main Q box and the mini.
- Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your main Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
- After a few minutes, the connected light on the booster should turn green. You're all set up.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your main Q box.
Then carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device,
You will be asked to press the WPS button on the Q booster box (not the mini as the Network reset will start the mini WPS automatically).
