Discussion topic: sky q. Had to disconnect my box now on reconnecting it will only play aps
Message posted on 31 Mar 2025 03:43 PM
had to disconnect my box for a a few dats now on reconnecting it will only play the aps
Message posted on 31 Mar 2025 04:04 PM
Re: sky q. Had to disconnect my box now on reconnecting it will only play aps
Hi @de76
Looks like it was disconnected from the Satellite dish.
Have you tried rebooting your Q box?
Failing this:-
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
