Discussion topic: Slow download and buffering
This message was authored by: St+from+un
Since changing broadband supplier from sky to a full fibre option  my sky Q is horrible it takes ages to download films and often stop midway to download more data, a speed check app shows 150 mbps. Tonight it took 10 mins to load a tv program on catch up yet if I don't use sky Q and use the smart tv the same program loads instantly, it almost feels sky are punishing people not using their broadband supply ( it worked fine when on sky) is there a fix for this?
Re: Slow download and buffering
Hi @St+from+un
Try completely resetting your Q network connection.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
If there is no improvement
Avatar for St+from+un
Il give that a go in the morning thanks
