Discussion topic: Sky q box switches off
This message was authored by: Martin168
Box comes on , shows the home screen then the box switches off
Re: Sky q box switches off
Hi @Martin168
Assume your Q box is well ventilated and not stacked with other devices.
Does it feel hot ?
If you can get into the Home menu try a Reset Settings in the Q box hidden menu.
Failing this
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
