Discussion topic: Skyq minibox
Message posted on 10 Aug 2026 07:44 PM
Skyq minibox
Not getting anything on tv ..Black screen with circle just going round and round. Skyq status says minibox activated. Have changed sockets rebooted etc
Message posted on 10 Aug 2026 08:17 PM
Re: Skyq minibox
Hi @HRJS
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
