1
This discussion topic has been answered Discussion topic: Skyq mini connecting
This message was authored by: Neagz
My sky q mini box won't connect to network or sky box. Via hard wire or wireless
Re: Skyq mini connecting
Hi @Neagz
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Hi @Neagz
Answered - Go to Answer
