Discussion topic: Skyq mini box
Message posted on 28 Dec 2025 07:03 PM
Skyq mini box
Message posted on 28 Dec 2025 07:06 PM - last edited: 28 Dec 2025 07:06 PM
Re: Skyq mini box
Just to point out you can't use your daughters mini box. It can only be used at her account address so she and you are breaking the T's and C's.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+. It’s worth mentioning that UHD content can’t be viewed on a mini box.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Re: Skyq mini box
Your daughter cannot give you 'her' box as they are all owned by Sky.
Message posted on 28 Dec 2025 07:07 PM
Re: Skyq mini box
Re: Skyq mini box
