Discussion topic: Help please
Message posted on 28 Dec 2025 07:12 PM
Help please
My main sky Q box is working fine but the mini sky Q box says in internet I've tried reset reboot and still not working it's a brand new TV and a new mint Q box from sky
Message posted on 28 Dec 2025 08:07 PM
Re: Help please
Hi @JillGraham
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
