Discussion topic: Skyq boxes
Message posted on 17 Nov 2025 06:04 PM
Skyq boxes
Almost on a daily basis my main skyq box and skyq mini box keep losing connection and I have to re set
Message posted on 18 Nov 2025 10:51 AM
Re: Skyq boxes
Assume this is loss of internet connection?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
