Discussion topic: Skybox
This message was authored by: Abdo+ahi
Skybox
My skybox in my bedroom won't connect
Re: Skybox
@Abdo+ahi if its a mini box Have you tried rebooting your main Q box ie
then rebooting the mni box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Skybox
Hi @Abdo+ahi
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
This message was authored by: 19651
Re: Skybox
Sky box massage is coming viewing card not reading
Re: Skybox
@19651
https://www.sky.com/business/help/articles/sb-problem-with-viewing-card
