This discussion topic has been answered Discussion topic: SkyQ minibox not responding
Message posted on 28 Oct 2023 01:39 PM
Newly installed SkyQ minibox not responding to remote control to try reboot or re-set.
Message posted on 28 Oct 2023 02:22 PM
@GD07 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 28 Oct 2023 03:13 PM
Re: SkyQ minibox not responding
That worked. The remote is rebooted and connecting with the minibox. Now just trying to get the box to connect to the router! Thx for the help.
Message posted on 28 Oct 2023 03:16 PM
Hi @GD07
Reboot the mini as above.
Message posted on 28 Oct 2023 04:57 PM
Thanks both for the input. I managed to reboot the remote, then reboot the minibox and then connect the remote to control the TV again. All up & running as should be now. Much appreciated.
