5
This discussion topic has been answered Discussion topic: SkyQ mini box
This message was authored by: SkiddyTaylor
SkyQ mini box
My HD channels have changed number on my SkyQ mini box. For instance SkySport Main Event HD was 401 now its 859, but on my main SkyQ box it is still 401.  Can I change them back?
This message was authored by: Laing1 Answer
Re: SkyQ mini box
@SkiddyTaylor Have you tried rebooting your mini box ie
if that doesnt work try rebooting your main box then your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: SkyQ mini box
Avatar for SkiddyTaylor
Re: SkyQ mini box
I have rebooted the mini box but no luck.  I'll try rebooting the main box. Thank you
Re: SkyQ mini box
@SkiddyTaylor the other things is that some times it comes back on its own 😀
Re: SkyQ mini box
Thank you that worked, simple really
Re: SkyQ mini box
@SkiddyTaylor no problem you are most welcome 😁
