This discussion topic has been answered Discussion topic: SkyQ connection to multiroom
Message posted on 22 Mar 2024 01:47 PM
I recently got a second multiroom box which I have connected to my Sky Q box. However if both multiroom boxes are switched on I get error message saying too many multiroom boxes connected. My understanding is that you should be able to watch TV on 2 boxes simultaneously. Anybody suggest ideas, setting etc. thanks
Message posted on 27 Mar 2024 03:23 PM
Hi Daniel
appreciate your explanation, sure enough I have the smaller memery Q box so I understand why I got the result from 2 multirooms. however as I won't need to use both boxes simultaneously this won't be a problem and I don't need to upgrade the Q box. Thanks TLeB
Message posted on 22 Mar 2024 01:51 PM
Re: SkyQ connection to multiroom
It will depend on which main Sky Q box you have…
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Hi Daniel
