Discussion topic: SkyQ box wont switch on
Message posted on 11 Feb 2024 10:30 AM
My sky lost satilite signal earlier in the week and now the box wont switch on. The orange light is on.
Message posted on 11 Feb 2024 10:37 AM
Re: SkyQ box wont switch on
Try the Sky Q recovery procedure from power off as described in step 2 here;
Message posted on 11 Feb 2024 10:55 AM
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
