7
This discussion topic has been answered Discussion topic: Occasionally losing sound and picture is stuttering on live and recordings, downloads are freezing.
This message was authored by: W+J
Briefly losing sound during viewing and picture is stuttering during the sound loss with live tv and recordings. Tv downloads are crashing out with message of no internet, but internet is fine.  Engineer replaced dish to box cable a week ago and checked system.
Re: Occasionally losing sound and picture is stuttering on live and recordings, downloads are freezi
@Quoman7 wrote:
@W+J wrote:
Tried that, no difference.
@W+J Try a Reset Settings in the Q box hidden menu.
After the Reset you will have to re pair your remote.
Lol
Said all that without moving my Lips .
You should credit the Author @Quoman7
Hi @W+J Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Avatar for W+J
Avatar for W+J
Quoman7, thank you for the advice, so far it appears to have cured the problem.
Lol
@oldfella if this was your work  apologies, I couldn't remember where I had stored it from?
I should have guessed, from the way it was so clearly written that it was one of yours? 👍🏻
@W+J the credit for posting an archived  solution to your problem was written by @oldfella
Avatar for W+J
Thank you both.
