Discussion topic: SkyQ box says I have no internet but I do! everything else in my house is connected and working!
Message posted on 03 Jun 2024 05:01 PM
My Sky Q box says "it looks like you do not have internet connection right now. If you're already set-up we'll keep trying to connect"
It has been like this for 24 hours now! I have switched the Sky Q box off, I have tried to re input my router/broadband password (BT not SKY) and it says there is an issue with it. I have tried to reconnect by using the WP button (or is it WPS?) and that doesn't work. I have turned the sky box off for over an hour to see if that helps.
I was watching Disney Plus through my Sky box and came out of what I was watching and then when I tried to go back in I could not access it.
Very annoying! as I clearly have internet access as I am typing this message on my laptop which is connected to the internet!
Message posted on 03 Jun 2024 05:06 PM
Re: SkyQ box says I have no internet but I do! everything else in my house is connected and workin
Hi @MrsM24
On 3rd party (non Sky) broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
