Discussion topic: Sky box connectio
Message posted on 03 Jun 2024 04:20 PM
Sky box connectio
Why won't my sky box connect to linksy router with befibre?
Message posted on 03 Jun 2024 04:27 PM
Re: Sky box connectio
Is 2.4GHz enabled?
Message posted on 03 Jun 2024 04:33 PM - last edited: 03 Jun 2024 05:16 PM
Hi @Rhoda56 It is impossible to suggest anything without a full description of your environment. Like is the box is in the open without interference from electronic equipment. How far away from the router is it and are your internal walls WiFi friendly etc. As already mentioned it has to use the 2.4GHz band. The more clues the better.
