Discussion topic: Sky Q box isnt working
This message was authored by: Andy165
I have reset the box but there is no output
Re: Sky Q box isnt working
Hi @Andy165
If the power led on the front right of the Q is Amber have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
If the light is green
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
