Discussion topic: SkyQ box multiple problems
This message was authored by: FiNic
Message posted on 11 Dec 2023 01:07 PM
My Q box has started playing up intermittently. Sometimes it records, sometimes not. Sometimes it plays recordings, sometimes not. Sometimes it says there's a technical fault with the channel, other times just a black screen. It also is now sometimes not playing channels. Have tried resetting several times and it seems to work for a few hours then goes faulty again.
Find out more
Message posted on 11 Dec 2023 01:11 PM
Re: SkyQ box multiple problems
You may need to contact Sky to get them to check/replace. Could be a failing hard disk.
