Discussion topic: SkyQ box beeping
Message posted on ā03 Aug 2025 01:47 PM
SkyQ box beeping
Our SkyQ box keeps bleeping even though and engineer has been and advised "the box doesnt beep only the remote does".
He then replaced our box and gave us a new remote, and yet days later, the box starts beeping again, (AND IT IS DEFINATELY THE BOX, as I took the remote out of the room, went back in without it and the box was still beeping.
Frustrated at this now.
It is also random and just when you think it's not going to do it again.....it does!.
Have tried ALL the suggestions that others have mentioned, to no effect.
Message posted on ā03 Aug 2025 01:57 PM
Re: SkyQ box beeping
Message posted on ā03 Aug 2025 04:12 PM
Hi and thanks for the reply. There are numerous answers in the community that have had the same sort of problems and I have Checked them all. Including sorted out the the remote control and making sure that in settings/accessability/beep on audio is switched off.
Restarted the SkyQ box then reset the remote control after restart.
Thething I am most annoyed about is that the engineer clearly thought I was an idiot and telling me the box doesnt beep, when clearly this one they have given us does.
Don't know what else to say really.
Guess as a 73 year old I must be lacking technical know how.
That's not having a go at you by the way......lol.
Message posted on ā03 Aug 2025 04:29 PM - last edited: ā03 Aug 2025 04:29 PM
I've never heard of the box itself bleeping, only the remote.
In previous topics people who thought their box was beeping found out it was something else nearby:
https://helpforum.sky.com/t5/Sky-Q/I-have-a-regular-repetitive-bleep-from-my-sky-Q-box/td-p/4533896
Message posted on ā03 Aug 2025 04:43 PM
Hi @arlanda Easy to test, turn off the Sky Q box at the mains.
Message posted on ā10 Aug 2025 12:43 AM
Just to add, ours got stuck on a red light (nothing recording, nothing scheduled) and then began beeping INCESSANTLY when I pressed the red button at front.
It is definitely the Sky box and it only began doing this in the last couple of days.
I did a full reset (switched it off, unplugged its power cable, left it for five minutes) and when I switched it back on, the red light was gone and it hasn't beeped yet.
Good luck - you're not going mad, the box CAN beep, but no bloody clue why.
Message posted on ā08 Jun 2026 03:30 PM
I'm having the same issue!! Mine is making different sounds each time tho and I cannot fathom it out
Message posted on ā08 Jun 2026 04:45 PM
@Tara1777 does it stop when you turn the box off at the plug?
Message posted on ā12 Jun 2026 11:04 AM
I unplugged everything and went through plugging them back in individually.. but t does stop when unplugged but continues loudly and annoyingly when there is power š«£
Message posted on ā21 Jul 2026 09:06 PM
Just had the same thing happen with ours. The tv locked so I switched the red button, centre front and the box started to emit a loud beeping sound which we couldn't stop. Only way to do it was unplug the damn thing! No idea what it was?!
Message posted on ā22 Jul 2026 01:07 PM
@Rachel1976 wrote:Just had the same thing happen with ours. The tv locked so I switched the red button, centre front and the box started to emit a loud beeping sound which we couldn't stop. Only way to do it was unplug the damn thing! No idea what it was?!
Hi @Rachel1976 It sounds like you activated the find my remote. I haven't used it myself, but I would imagine pressing a button on the remote would stop it.
