4
This discussion topic has been answered Discussion topic: SkyQ TV Guide Display - Black text on white background?
This message was authored by: Davidstevan
All of a sudden the TV Guide on my SkyQ box is displaying black text on a white background rather than white text on a blue background.  My SkyQ mini box is displaying white on blue.
The "High contrast" setting in "Accessibility" is set to "off".
I've attached images to demonstrate.
Where has the black on white come from and how do I get it back to white on blue?
7C82C34F-DFF5-49D5-90E9-327A6FF6BACB.jpeg5DEF45EE-4C5A-4C6E-8B25-ADFE9D545B15.jpegSkyQ mini
FEEFB10F-CED4-4302-AF68-98C4DD0B2915.jpegMain box
I've performed a power off and power on but this has not solved things.
This message was authored by: best+of+the+best Answer
Re: SkyQ TV Guide Display - Black text on white background?
Hi @Davidstevan in the Accessibility menu the Highlight Programmes you have got an S at the side meaning all programs with the S symbol will be highlighted
Just select none instead of subtitles
Hi @Davidstevan
Avatar for Davidstevan
Level 3 icon
Thanks very much @best+of+the+best  your advice worked a treat.
Thanks also @oldfella  for your reply.
I have a suspect for changing the settings but can't be angry with a two year-old! 😂
You're welcome @Davidstevan
Answered - Go to Answer
