Discussion topic: Disney + and Netflix not working
Message posted on 18 Apr 2023 06:55 PM
Has anyone experienced problems with sky q box not allowing Disney + and Netflix not to work, I just get a message saying sorry there's a problem
also if my kid watches YouTube on sky a box I have no sound when I return to tv
any suggestions
Message posted on 18 Apr 2023 08:16 PM
Re: Disney + and Netflix not working
any suggestions
Hi @Daryl82
Message posted on 18 Apr 2023 10:05 PM
