5
This discussion topic has been answered Discussion topic: SkyQ MultiScreen Pack
This message was authored by: AdelaideK15
Please can someone tell me what this is etc? Much thanks in advance ☺️ A Kendall
This message was authored by: SKY1992bf Answer
Re: SkyQ MultiScreen Pack
@AdelaideK15  If you have more than one box the multi screen subscription allows you to access the content on the others
hi @AdelaideK15
The multiscreen Pack is not a current option.
If you are enquiring over this with an older subscription (on older base packages) then it allowed you to not only watch on mini boxes and recordings on SKY Go but also enabled UHD .
Nowadays there is only Multiscreen add on (not pack) which only allows you to watch on mini boxes and recordings on SKY Go - UHD is now a separate add on (with SKY Signature Base package)
Avatar for AdelaideK15
Hi 👋 Nigea99 ✨️
Thankyou hugely for replying to my query so quickly. That's helped alot so thankyou. I've had this for a very long time...was thinking of cancelling it to save some money but won't now because it'll prevent me watching recordings on both devices.
Thanks again. Kind regards ☺️
@AdelaideK15 wrote:
Hi 👋 Nigea99 ✨️
hi @AdelaideK15
if you do still have the Multiscreen pack and an older base package, then you may possibly save a little money by moving onto the latest base package and add ons - especially if there are discounts available & SKY Signature includes Box Sets (in SD)  as standard which was an add on with older packages,
Not guaranteed but possibly worth calling SKY to find out - although do get them to fully explain any differences
Hi again Nigea99
Brilliant...ok will def do that once I've got my voice back and can call them. You've been exceptionally helpful and I'm very grateful.
Much thanks 😊 🤜🤛
