Discussion topic: Sky won’t turn on
This message was authored by: Keeks13
Sky won’t turn on
Sky not working
Re: Sky won’t turn on
@Keeks13 wrote:
Sky not working
Hi @Keeks13
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
