3
This discussion topic has been answered Discussion topic: Sky will not react with remote control
This message was authored by: Millie6666
Sky will not react to remote control, had to turn it on from sky box stays on one channel I have changed batteries, turned it off and back on what can I do now
This message was authored by: Quoman7 Answer
Re: Sky will not react with remote control
Hi @Millie6666 Try completly resetting your Bluetooth remote. Press and hold 7 & 9 together on the remote until it's led flashes four times. Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Avatar for Millie6666
Level 0 icon
Thank you so much, done what you said and it worked a treat. Thank you.
@Quoman7
Mmmm.
