Discussion topic: Sky q with Deco mesh system
This message was authored by: murphy78
Hi
We have recently bought a Deco X55 mesh system to improve the WiFi around our house.
Unfortunately this has caused problems with our 2 sky Q mini boxes as they won't connect to the main sky Q box now?
They can't be hard wired unfortunately so rely on WiFi.
I have set up the deco as an access point so it distributes the WiFi and the the sky router has WiFi switched off.
Can I turn WiFi back on on the sky router and change the SSID so only the sky q boxes connect to it or will they cause too much interference?
TIA
Re: Sky q with Deco mesh system
Might be ok. Use different channels
or worth trying hard wiring the minis & Q into a deco node each.
