5
This discussion topic has been answered Discussion topic: Sky tv
This message was authored by: BrenHill
Sky tv
Unable to get TV to switch to full screen not sure if faulty remote or faulty sky q Box
This message was authored by: MightyQuinn Answer
Re: Sky tv
Hi @BrenHill   Are you talking about aspect ratio? The TV aspect ratio is controlled by your TV, not the Sky Q box.
Re: Sky tv
What do you mean by 'full screen'?
Re: Sky tv
Avatar for BrenHill
Re: Sky tv
To Mighty Quinn
Have sorted full screen it was Tv aspect not set up properly
This message was authored by: Royf59
Re: Sky tv
I've tried to change the settings so that I've got full screen view instead of letterbox when watching some movies. TV people ( 4 different companies) say it should be within the Sky q as it's supplying the signal to the HDMI. I'm fed up of it tbh
Re: Sky tv
They are all wrong. The TV decides what it does with the incoming 16:9 HD or 4K signal.
