Discussion topic: Sky tv
This message was authored by: Henry29
Sky tv
My satellite dish isn't working
Re: Sky tv
@Henry29
You will have to give your fellow customers more to go on. What makes you think it's the dish and not your Sky Q box? Any error messages appearing on your screen?
Avatar for Henry29
Re: Sky tv
Yes it's coming up on the screen that there is a problem with my satellite dish my screen keeps oscillating then the screen goes blue and the message about my dish comes up then the screen goes black.
Re: Sky tv
@Henry29
See this link for troubleshooting
you may end up arranging an engineer to check if your dish has moved out of alignment.
Avatar for Henry29
Re: Sky tv
Thank you
