Discussion topic: Sky tv stopped working
This message was authored by: DavidYates
Sky tv has stopped working. Orange button showing in front
Re: Sky tv stopped working
Hi @DavidYates
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
