Discussion topic: Sky tv issue
This message was authored by: Raman2
Sky tv issue
Good morning
i am having issues with sky tv, everytime we use sky the tv is glitching
Re: Sky tv issue
@Raman2 wrote:
Good morning
Hi @Raman2
Try a Reset Settings in the main Q box hidden menu.
Re: Sky tv issue
If by 'glitching' you mean audio/visual breakup then it could be your dish alignment.
