Discussion topic: Sky q main box wont turn on even after taking plug out
Message posted on 02 May 2024 09:44 AM
We had a storm last night and a house in next road got hit, after this our sky q box turned off and now won't turn on. Its stuck on the standby and won't change even after taking plus out. Help!!
Message posted on 02 May 2024 09:49 AM
Re: Sky q main box wont turn on even after taking plug out
Follow this: https://www.sky.com/help/articles/sky-q-box-wont-turn-on
If the box has been damaged then you'll need to contact Sky for a replacement.
Message posted on 02 May 2024 09:52 AM - last edited: 02 May 2024 09:54 AM
Hi @Akccca
If the Amber standby led is still on,
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
