Discussion topic: Sky sports mix
This message was authored by: twinbooth
Sky sports mix
Should I be able to record a live football match on sky sports mix?
I have sky q
The attempt failed last night
Re: Sky sports mix
I have sky q
@twinbooth what happened when you tried ? what messages did you get ? etc
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for twinbooth
Re: Sky sports mix
Hello. No message received. Just didn't record.
the culprit might be user error /elderly hubby I am thinking because I have just tried recording something and it worked no problem!
do you think we should always be able to record on this channel .. which hubby seems to have just discovered
thanks for bothering
Re: Sky sports mix
Hi @twinbooth
Shouldn't be any problem recording on the Sky Mix channel.
