This discussion topic has been answered Discussion topic: Sky signature
Message posted on 16 Jan 2025 09:02 PM
What programmes do I get with sky signature
Message posted on 16 Jan 2025 09:11 PM - last edited: 16 Jan 2025 09:17 PM
Message posted on 17 Jan 2025 01:40 PM
Re: Sky signature
Thanks for your help it's just as went go into sky Atlantic it says press red button to up grade when I thought it came in my package I'm not very good with all this
Message posted on 17 Jan 2025 01:42 PM
Re: Sky signature
hi @Lesley98
As you should have seen SKY Atlantic is included but it is in SD as standard
As the default download quality is set to HD (high Definition) not SD then if you don't have the HD add on, when you try to download and watch you are prompted to upgrade (i.e. take out the HD subscription)
You, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
Message posted on 17 Jan 2025 01:54 PM
Re: Sky signature
That sound awfully complicated as I'm new to this not sure I understand what I have to do
Message posted on 17 Jan 2025 01:58 PM
Re: Sky signature
I think I will wait for family to visit they may know thanks for info
Message posted on 17 Jan 2025 01:59 PM
Re: Sky signature
When on the main Home Page. scoll down to Settings
Then Tab Right & scroll down to Setup
Tab Right Again & scroll down to Preferences
Tab right again and scroll down to 'On demand default download format
Tab right & select 'SD' & press Enter
You can then exit using the Back/Dismiss button and when you download programmes in futire you should get the SD version
