Discussion topic: Sky remote
This message was authored by: Sweenytodd
Message posted on 28 May 2025 09:19 PM
Sky remote
My voice control doesn't work
Find out more
Message posted on 28 May 2025 09:23 PM
Re: Sky remote
Hi @Sweenytodd
Try resetting your broadband router.
