Discussion topic: Discovery plus sky Q
This message was authored by: Timskybad
Message posted on 28 May 2025 11:03 PM
Every time I go to use discovery plus app it fails to work . Black screen when play anything. No wonder it is free
Find out more
Message posted on 29 May 2025 06:37 AM
Re: Discovery plus sky Q
Do your other apps work ok?
Try repowering your Sky Q box along with a reboot of your broadband router.
Also, refesh your apps;
- Press Home on your Sky Q remote, then highlight Settings
- Press 0,0,1 and Select to access the Installer menu
- Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
- Press Dismiss to return to normal viewing.
The refresh can take 24 hours to complete.
Sky Community Superuser. What is a Superuser? Click here to find out
